I'm designing a low-power, battery-powered sensor node using an ATtiny1626 microcontroller (1.8V~5.5V supply with low clock speed), powered directly from 2x AAA batteries (various chemistry, let's say 2V up to 3V over usable life).
For providing supply for other parts of circuit, a hi-efficiency boost converter XC9141B/42B is used. The chosen version with B suffix, bypasses the input voltage to the VOUT
pin when the CE
pin is low and the VOUT
would be more or less equal to VBATT
in that case. When the CE
goes up, VOUT
also goes up from VBATT
to 3.3V.
In order to get rid of level translations, I thought about supplying the MCU from the VOUT
pin itself; so the MCU (still powered from pass-through capability) holds the supply voltage at VBATT
and when needed, turns the boost converter on, and the supply of MCU and the other part of circuit jumps to 3.3V.
- The other parts have their own sleep modes, so it's not a problem if they still get powered by
VBATT
or when the voltage jumps between values. - The idea is to boost voltage when the battery level is low and unable to power other parts sufficiently, and maybe for better TX power of LoRA (SX1278 module.
What kind of problems would arise from this sudden switch of voltage for the MCU itself?
