Could someone please tell me what is the value of Ux? How can i calculate it?
is Ux = (U1 - U2) * R2/(R1+R2) correct?
The opamp should be seen in such way ideal that its input current can be assumed to be zero. Hopefully you in some phase learn the cases when such assumption can be done without causing too much error nor totally blocking the functionality of the opamp. That's very important in making practical designs.
If the input current of the opamp can be seen = 0 the circuit is double input voltage divider. Solve it by using superposition. Assume at first U2 = 0V i.e. connected to the circuit ground. Calculate how much U1 generates to the opamp input. Assume it's = Ua.
Assume then U1 = 0V i.e. connected to the circuit ground. Calculate how much U2 generates to the opamp input. Assume it's = Ub.
The total input voltage is Ua+Ub. Your own formula is wrong.
The end.
