Assumptions:
I'm assuming you need to preserve the amplitude and frequency information of your signal. Therefore, you need a linear amplifier, which means, you need negative feedback. I also assume you don't mind inverting the signal as long as the gain=1.
The Simplified Amplifier Circuit Architecture
CMOS inverters lend themselves easily for inverting amplifier implementations, as we can readily use the 1st stage inverter gate as the virtual ground. See the circuit below:
You can only do this with an odd number of stages, otherwise you don't have negative feedback. However, 1 stage only might provide too low of a loop gain (thus, poor distortion) and 5 stages will probably be a nightmare to frequency compensate. 3 stages should be the sweet spot.
Problem: Inverter's sensitivity with respect to supply voltage
Unfortunately, an inverter's transconductance can vary significantly over temperature and process corners and supply voltage. The process variation you can't avoid, the temperature and voltage variations you can with the solution below.
Solution: Dedicated Voltage Regulators for the stages
One way to overcome this is to bias your inverters such that they have a dedicated current through them, and have them track over temperature. To this end, you can design a regulator that provides a replica voltage to your inverters supply, like this:
(BTW, I'm just drawing schematics to illustrate my ideas, I didn't simulate any of these.)
The nice thing about this regulator is that, say, if your "model/replica" inverters (M2 and M3) are of size \$W/L\$, and have a current \$I_b\$, then, in your actual stage, you can scale up your size as \$k\times W/L\$ and your current will be scaled up accordingly as well (it's a replica/model-based kind of biasing, so it'll never be super accurate, but you get the idea).
Extra Suggestion
As an extra, there might be a possibility of distorted currents from the 2nd stage coupling via the supply to the 3rd stage, which dominates distortion. That means it can have more distortion than usual. A way around this could be isolate the supply by putting dedicated regulators for 2nd and 3rd stage. Perhaps 1st stage can share the regulator with the 2nd. You have to experiment.
