Datasheet of STM32F103X8
I found the sensor output a voltage ranged 0~5V, which is higher than the ADC port can tolerate with (in STM32F1XX datasheet all ADC ports can only tolerate 3.3V).
How to make it accessible to input 0~5V ,without destroying MCU and, not losing too much accuracy of analog voltage input?
Datasheet of sensor
    \$\begingroup\$ You can use a voltage divider circuit to scale down the voltage from 0-5V to within the range that the ADC port can tolerate (0-3.3V). \$\endgroup\$
    – liaifat85
    Commented Mar 23 at 8:08
  • \$\begingroup\$ @liaifat85 For example tandem resistors voltage divider? \$\endgroup\$
    – s sss
    Commented Mar 23 at 8:39
    \$\begingroup\$ To help get an answer can you edit the question and include a link to the datasheet for the sensor. Depending upon the output impedance of the sensor may affect how a voltage divider with resistors can be achieved. \$\endgroup\$ Commented Mar 23 at 12:13
    \$\begingroup\$ The link to the datasheet of sensor which has been added to the question is https://file///C:/Users/Dell2/Desktop/TSW-30.pdf. I.e. a link to a file on your PC and therefore not visible to others. \$\endgroup\$ Commented Mar 23 at 14:24
  • \$\begingroup\$ @ChesterGillon Thanks...ehh but how to upload file in the question though? \$\endgroup\$
    – s sss
    Commented Mar 23 at 15:38
