I have a square wave generator that puts out roughly 200 kilohertz of pure square wave signal. When I give this square wave which is I am sure it is a square to the base of a transistor (NPN) the output turns into something that I would call shark fin wave. The rise has a curve but the fall is perfectly perpendicular. What am I doing wrong?
@Burglups "Welcome. A schematic could ..........." Thank you friend for your warm welcome. Here is the schematic of my entire project. It is going to be a soldering Iron . Thanks for taking time to reply to my post
@periblepsis "Hrmann, You have said what entirely different? I can't tell......" Thanks friend for cool and nice sketches and clarifying points I really learned a lot from your sketches and commentary that was added. I'll definitely benefit a lot from these lessons in the next steps of my project.
@Justme "What is the purpose of buffering the NE555...." The purpose of my original circuit is not only buffing the output but also reversing the duty cycle with off-cycle. I have this nice little pulse module N555 (see photos) and it allows me to adjust the frequency as well as the duty cycle. in my project though I need a lower duty cycle because I am working with higher voltage. Unfortunately when I try to reduce the duty cycle the model output becomes really unstable and one of the potentiometers gets a little warm. From the other side I have pretty much no limitation and I can increase the duty cycle to something like 90%. My idea was that in my original circuit, the R1 was gonna provide the voltage for the gate of ES170 MOSFET and when the transistor switches, it should ground the gate of the MOSFET and thus turning it off. The turn off part is working fine but turning on is kind of gradual (shark fin) which is gonna heat up the mosfet and probably kill the MOSFET. My project is building Weller soldering gun. Here are the materials that I have, the simplified diagram, and here are my findings so far:
- Lowering the duty cycle, since the input to the primary winding is relatively high (110v) is actually the solution (by my understanding) since the ferrite core reaches saturation fast and no need for longer duty cycle. -It somewhat works but the heat produced by the secondary winding is not even close to what I need
- the D1 (reverse induction protection) gets hot. Even 5A diod gets too hot, especially when there is no load on the secondary winding.
- The interesting part was that as soon as I short the secondary winding, the linear light dims a bit when I expectet more current go thru the circuit, -the primary winding is roughly 100 turn, but I have no way or knowledge to calculate the precise loops so I go but gut feeling
@ Michal Podmanický ..... for 200kHz I would use some fast switching signal transistor. Thanks friend! I will give it a shot and will let you know how it changed the results. . Cheers!!! @ D.A.S.'s Friend Thanks!! But too technical for me! I appreciate if you could elaborate a bit or suggest some books etc, to help me understand those vccrccr.... stuff enter image description here
