working on a project with STM32F103 and need to measure couple of external voltages. I have a simple voltage divider setup like the attached circuit, but the output of the divider is surprisingly different that I can calculate..
I calculate the output at around 2.9 V, but on PCB this gives me only 1.9 V. Any idea, what can cause this? I have tried measuring the output of the divider by disconnecting the trace that connects to MCU, but the same result.
The resistance values are correct (measured with multi meter). What else should I look at to debug it?
The Zener datasheet is here https://evelta.com/content/datasheets/273-MM1Z3V3B.pdf
============ UPDATE =============
After further debugging, I see that the Zener is dropping the voltage. Zener reverse current? But datasheet says only 20 µA.
