Gate Driver: UCC27710 Application: 1Kw 3-Phase Motor Driver
Texas Instruments has a document on Bootstrap Circuitry, they describe the circuit as: enter image description here
(Ignore red line)
However, in the datasheet of the gate driver UCC27710, the circuit is displayed without R_Boot:
My question: Am I able to Ignore R_Boot in this application? Its better design wise, as I don't have to deal with the time constant delaying startup time.
My schematic: HS = High Side MOSFET gate LS = Low Side MOSFET Gate
References:
UCC27710 Datasheet https://www.ti.com/lit/ds/symlink/ucc27710.pdf?ts=1731886224722&ref_url=https%253A%252F%252Fwww.google.com%252F
Bootstrap Circuirty: https://www.ti.com/lit/an/slua887a/slua887a.pdf?ts=1731886856654&ref_url=https%253A%252F%252Fwww.google.com%252F
    \$\begingroup\$ I would use a Rboot. The capacitor shouldn’t be charged (or discharged) without some series resistance. \$\endgroup\$ Commented Nov 18 at 1:26
  • \$\begingroup\$ Rboot is "part" of the diode ... \$\endgroup\$
    – Antonio51
    Commented Nov 18 at 8:37
The bootstrap resistor can slow turn-on of the high side FET, which can reduce switch node ringing. It will also limit peak current in the capacitor.
You should be able to calculate a value that doesn't significantly delay your startup, but if you have to you can operate without the resistor. I've seen 100s of successful bootstrap circuits without a resistor.
If you do decide to do without it, and you have space, put pads for the resistor on the board and stuff it with a 0-ohm resistor. That way if you have issues with ringing, EMI, etc. you have a way to experiment with other values without spinning the board.
