There is a Problem in our textbook which asks us to find, using Kirchoff's law, the voltage across component v_x and v_y.
According
I know that the voltage at node 1 should be 14 volts from [21 + (-7)]=14 (in terms of $$v=\frac{dw}{dq}$$ not in terms just of potential difference.
The voltage across V-x is 9 because the voltage across the two components in series right below it is 5.
Of course, v_y is 14. This said:
Is there going to be any voltage across the rightmost component?
