I am making a basic circuit to test the responsivity of a phototransistor.
I made a basic circuit using a phototransistor connected to 5V and a 22kOhm resistor. On the other side of the phototransistor is a Red/Green LED that has equal mcd ratings for both colors.
My problem is that, even when I calibrate for I_f, the detected voltage from the red LED is much higher than the green LED -- to the order of 2.5x or higher. This result does not agree with the phototransistor datasheet, which says the difference in responsivity is not that high.
For reference: I am using the PT908-7C-F phototransistor and the SSL-LX2577IGW R/G LED. However, these results seem to be independent of phototransistor and LED, as I have been able to reproduce this result with another phototransistor/LED setup in the past.
I am at a loss as to what could cause this result. Short of obtaining a laser/light power meter from my other lab to verify my results, what could be a possible explanation? mcd ratings are not reliable? Line width? Actual responsivity curve more steep than reported on datasheet?
