I have salvaged some parts that I can't identify myself. I would appreciate it if someone could tell me what they are called so I can look them up.
I took some better photos of the first 3 parts, and added a 7th at the bottom. Sorry about #3, but it is convex from all sides, and I don't have a light diffusor (yet).
part 1 better1: 1
part 2 better2: 2
enter image description here3: 3
4: 4
5: 5
6: 6
part 7
Sorry for the low quality of the photos. I'll get better with more experience with my camera.
  • \$\begingroup\$ My guess, in order from top to bottom: Unknown; some kind of diode; 4MHz ceramic resonator; Unknown; Unknown; 1KV MOV, or 1KV rated 10pf ceramic capacitor. Most of them look like they come from overload protection circuitry - often seen on telephony interfaces, like ADSL. \$\endgroup\$
    – Majenko
    Commented Jun 21, 2014 at 16:37
  • \$\begingroup\$ Could the first one be an inductor? \$\endgroup\$
    – piyush
    Commented Jun 22, 2014 at 9:26
  • \$\begingroup\$ My votes: 1. inductor; 2. diode, or if the outer bands are equally wide it may be a DIAC; 3. 4MHz resonator; 4. diode (partial partnumber BYV); 5. filter or resonator; 6. capacitor; Where did you find them? \$\endgroup\$
    – jippie
    Commented Jun 22, 2014 at 10:07
I suspect the first one is a light detector of some sort.
From the size of its leads, the second one looks like a Zener diode, but for sure it's a diode of some kind.
The third one is a 4.0 MHz ceramic resonator with internal caps for use in a Pierce oscillator.
From the "BYV" legend on the fourth one, it's a high-speed rectifier of some sort. The rest of the legend would probably single it out.
The fifth one, a transistor? a dual diode? ???
The sixth one is a 10pF 1kV ceramic capacitor
Views showing more legending would be helpful.
  • \$\begingroup\$ I'd rather say the 5th is a filter too because it looks moulded. \$\endgroup\$ Commented Jun 21, 2014 at 19:35
