I am confused by the primer on control theory found at the end of the following paper, which concerns an instance of integral control in a biological system. Since it concerns integral control, I thought electrical engineers might be better able to answer. I apologize if the article is behind a paywall but it is a very popular paper evidently, so you may be able to google for a pdf.
Yi et al. (2000). Robust perfect adaptation in bacterial chemotaxis through integral feedback control. http://www.pnas.org/content/97/9/4649.abstract
Within the primer, the authors use as an example of integral control a heating system where the power setting on a furnace is proportional to the difference between a thermostat's set point and the ambient temperature. The claim is that this is not proportional control because the temperature in the room is the integral of the heat released, and the system is responding to error in temperature. I thought an integral control system would need to keep track of past temperature deviations from the set point. Is their argument accurate, and if so, could someone explain?
To be slightly more specific, one reason I have trouble grasping their argument is that, I imagine, if a window were left open (so that heat was constantly being lost from the room) then the heating system would never adapt but would operate with droop just as a proportional heating system would...right?
Thanks for your help!
