I've an Enable pin active-high that have maximum voltage rating of 3.0v, but I use a 3.3v MCU outputs. I've also a 3.0v voltage regulator on board.
Should I use resistor voltage divider or there is a possibilty to use 3.0v voltage regulator? And how should I connect it?
