Is the following test bench correct? I tried to use a text file with the content
00
01
10
11
to test an architecture of an and port.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_misc.all;
use std.textio.all;
entity my_and_tb is
end entity my_and_tb;
architecture tb_arch of my_and_tb is
component my_and is
port ( x, y : in std_ulogic;
z : out std_ulogic);
end component;
signal x_tb, y_tb, z_tb : std_ulogic;
begin
my_and_inst : my_and port map( x => x_tb, y => y_tb, z => z_tb);
tb_process : process
file my_input : TEXT open READ_MODE is "my_input.txt";
file my_output : TEXT open WRITE_MODE is "my_output.txt";
variable my_line : LINE;
variable my_input_line : LINE;
variable my_output_line : LINE;
variable x_bit : bit;
variable y_bit : bit;
variable z_bit : bit;
begin
while not endfile(my_input) loop
readline(my_input,my_line);
read(my_line,x_bit);
read(my_line,y_bit);
x_tb <= to_stdulogic(x_bit) after 5 ns;
y_tb <= to_stdulogic(y_bit) after 5 ns;
z_bit := to_bit(z_tb);
write(my_output_line,z_bit);
writeline(my_output,my_output_line);
wait for 10 ns;
end loop;
end process;
end architecture tb_arch;
Basically the simulation with ncsim is blocked... Update...
Same problem for this example (is a flip flop d, and basically the clock make me confuse, i thought it was ok but it isn't... could you help me?)
library ieee;
use ieee.std_logic_textio.all;
use std.textio.all;
entity ff_d_tb is
end entity ff_d_tb;
architecture ff_d_tb_arch of ff_d_tb is
component ff_d is
port(clk, d : in std_logic;
q : out std_logic);
end component;
signal clk_tb, d_tb, q_tb : std_logic;
begin
ff_d_comp : ff_d
port map(clk => clk_tb, d => d_tb, q => q_tb);
clk_process : process
begin
clk_tb <= '0','1' after 5 ns;
wait for 10 ns;
end process;
ff_process : process
file in_file : text open READ_MODE is "input.txt";
file out_file : text open WRITE_MODE is "output.txt";
variable l_in : line;
variable l_out : line;
variable q_loc, d_loc : std_logic;
begin
while not endfile(in_file) loop
readline(in_file,l_in);
read(l_in,d_loc);
d_tb <= d_loc after 5 ns;
wait until falling_edge(clk_tb);
q_loc := q_tb;
write(l_out,q_loc);
writeline(out_file,l_out);
end loop;
wait;
end process;
end architecture ff_d_tb_arch;
