I am currently working on this small circuit which as you can see, has to level shift a 3.3v 1Hz PPS signal into a 5v pulse.
Everything is marvelous when I measure the level shifted pulse with the CRO leads with ground springs (rather than leads) right off the CMOS gate.
However, this design is going to carry the output pulse from my PCB to the destination using some loose wires (Not a shielded cable which doesn't get effected).
And these loose wires introduce the following coupling effect to my design.
How I know this? In my 3D electronics version, I have added a bunch of zip tied loose wires to my signal, ground and Vcc wires (exactly how the final product is going to be) and measured the signal at the end of loose wires with the perfect CRO leads with spring grounds.
Wanna make it harder for you? I cannot use heavy filtering on the input or output pulse as this device is used for a time measurement and correction purposes with a 300ns rise time limit, so we wouldn't want to slow down the rising time.
How can I prevent this coupling from happening while using loose wires to carry the signal?
