Above is a part of a BJT common emitter amplifier with 15V Vcc(all caps ignored for DC). I was following a tutorial which explains how to setup parameters step by step. When explaining the DC biasing section, the tutorial first sets up values for Q point Vce i.e VceQ, Rc and Re.
For a maximum Vout swing, we should choose VceQ as Vcc/2. This can be seen by a DC load-line. I think it is because the maximum change in Vce will logically yield a maximum swing in Vout. At Q point we can then take VceQ = 7.5V. So far so good..
Then the tutorial chooses the ratio of Rc/Re as 3 i.e Rc = 3*Re. And then it goes to investigate other parameters without explaining why the ratio is 3.
I tried to setup this ratio first 3 and then 4 and then 14. What I found out is the more the ratio the more swings the Vout.
Since we know Vcc = 15V and at Q point VceQ = 7.5V, we can check Vout for different Rc/Re ratios.
Case_1:
Lets first take Rc/Re as 3 as the tutorial suggests:
Vout_max (when Q1 is in cut-off) becomes: 15V
Vout_middle (when bias current is zero) becomes: VceQ + (15-VceQ)/4 = 9.5V
Vout_min (when Q1 is in saturation and Vcesat = 0.2) becomes as follows:
Vcesat+(15-Vcesat)/4 = 3.9V
So what we see above is a Vout which has a middle point at 9.5V when no bias current exists and which swings up to 15V and down to 3.9V. This corresponds a total swing of 11V.
Case_2:
Now lets take Rc/Re ratio as 14 and redo the same calculation:
Vout_middle (when bias current is zero) becomes: VceQ + (15-VceQ)/15 = 8V
Vcesat+(15-Vcesat)/15 = 1.2V
Here what we see above is a Vout which has a middle point at 8V when no bias current exists and which swings up to 15V and down to 1.2V. This corresponds a total swing of around 14V.
Here is my question:
1-) If my logic is right it seems to me Rc/Re ratio determines the Vout swing (after setting VceQ as Vcc/2). And the Vout swing increases with Rc/Re ratio. Is that right?
2-) Of course Re shouldn't be too small but what is the rule of thumb here for Rc/Re ratio? And why?
