If you could please bear with me: I'm just starting out in electronics and I've had an idea for a nice experimental mod that will also be useful.
I've recently bought a pretty cool little 8 x 8 LED spectrum analyzer off eBay:
And I'm currently building a container for it. I'm going to add a couple of mods. Among them, an ON/OFF switch, so I can get rid of the USB connection and have it permanently connected, but only ON whenever I really need it.
The thing is, this little device has a couple of configurable settings, none of which are, by default, the ones I prefer. So after installing the ON/OFF toggle, every time I toggle the device off, I'll lose my settings, and have to reconfigure them when toggling it back on... which is of course a hassle, because this is meant to be a little decorative plus when I turn on my music and relax, not a task to complete every single time.
So I've been researching what would be the best (slash-maybe-not-the-most-complex) way of adding the possibility for the device to remember its settings even when disconnected to power (or powered off).
I've read a couple of forums and articles and have come across the terms latching relay and slow-discharge capacitor... but I'm still mostly lost. I'm even wondering if just adding a coin cell at some point will do the trick but I'm almost sure it can't be that easy!
So if anyone could put me on the right track, in other words tell me, based on this specific project, what's my best bet, that'd be GREAT! Because right now, after a couple of days of research, I've turned out nothing, at least nothing I can make any sense of.
Thank you in advance!
P.S. Or... is there a way to reconfigure the WD1088S chip?
P.S.S. I've just had another idea... it might be a bad one, but I'm not sure if it won't actually work OK. This device works with 3-5V and has a "static working current [of] less than 3mA". So what if I attach it to a 3.6V 1240 mAh camera battery and have the charger connected to the battery with the ON/OFF toggle in between. That way, at least, I won't be using the electrical current while the device is not in use. Yes, the device won't really be OFF, but as long as it's kept idle, it should have enough power to not turn OFF during about 12 days. I can even use it with the battery (it should work about a day, with an working current of 30mA). I know it's not an elegant solution, more like a workaround... But it's the only thing I can think of. What I'm afraid is I'll be contributing to shortening the lifespan of the whole thing... Anyway, I'm out to learn, so what do you think of this idea?
Edit: I found the PCB schematic and the IC datasheet. Perhaps that can help...
