6
I would like to model a transformer in LTspice with hysteresis and saturation (or just hysteresis would be nice). I have already tried the Chen model which I don't like and tried to model a regular transformer with the inductor parameters found here but got an error.
Here is an example of my LTspice netlist
.param Is=2A a=3
.param Ind 1000mH
K2 L4 L3 1
L4 0 N008 {2*Ind} Ipk=2 Rser=10
L3 0 N007 flux={Ind*Is}*tanh((x/{Is})**{a})**{1/a} Ipk=2 Rser=110
I get an error that says: mutual inductance statements aren't supported between arbitrary inductors
My question is: is there some way to combine an ideal transformer and a non-linear inductor to make an accurate model and simulate in LTspice?
Are there other ways to effectively model a transformer with hysteresis in spice?
5
I found a great article at this site to model transformers. It explains
"The work of Hsu, Middlebrook and Cuk 2 develops the relationship of leakage inductance, showing that relatively simple measurements of input inductance with shorted outputs yield the necessary model information."
They developed this for IsSpice, but it could be applied anywhere. Here is the spice code for a saturable core (just in case the link goes down) enter image description here Here is an included picture of the model enter image description here This is a graph of a modeled core: enter image description here
And here is the reference for the paper the article was based on: TRANSFORMER MODELING AND DESIGN FOR LEAKAGE CONTROL Shi Ping Hsu, R.D. Middlebrook and Slobodan Cuk, Power conversion International, pg. 68, Feb, 1982
  • \$\begingroup\$ Can you please explain how to calculate the parameter Lsat and Feddy .The paper have explained it but i couldn't understand it. \$\endgroup\$
    – Israr
    Commented Jul 18, 2021 at 15:07
You should check out this page (and, maybe even the rest of the site): transformers. Even the manual should have told you about the possibility of having a Chan core in LTspice, while looking at the default examples that come with the installation of LTspice, should have given you a nice example of using it. I've pointed you in the right way, so now I'll leave it to you the pleasure of finding out, rather than coming up with a silver platter. :-)
  • \$\begingroup\$ Lt wiki is a great site, I use it on a weekly basis \$\endgroup\$
    – Voltage Spike
    Commented Jul 19, 2016 at 15:21
