I am trying to use Find similar object in Altium designer to change all designator font in my schematic at once. First I Right-click on any designator on the schematic and select Find similar object and Ok. this makes all designators in the sheet to be highlighted. Sch inspector is opened and I select FontId to change the required font. Later I expect that all designator fonts will immediately be changed but actually nothing is happened, Why?!
  • \$\begingroup\$ If I try that then it is not FontId that I change but just Font. \$\endgroup\$
    – Steve G
    Commented Aug 5, 2016 at 11:59
That is because you must Enable "Select Matching" in Find similar Objects. Then press OK and continue to change FontID. That should work!
    \$\begingroup\$ Woow! it works well now.. \$\endgroup\$
    – yaya
    Commented Aug 5, 2016 at 12:16
