As per the definition,
A boolean function is said to be complete if
  • It derived all the basic operations
  • It reduces to another function that is already known to be functionally complete.
What inferences can be draw in light of this definition and what exactly do we mean by a functionally complete boolean function.
  • \$\begingroup\$ Without some context : it's meaningless. If this is part of a course, reference the course and textbook you are using in the question. \$\endgroup\$
    – user16324
    Commented Sep 24, 2016 at 10:03
  • \$\begingroup\$ Generally, if you want help with coursework or similar, you need to ask something much more specific. You generally won't get an easy answer to the original question here. If there is a detail which you don't understand, ask about the detail and show you understand the rest. \$\endgroup\$ Commented Sep 24, 2016 at 12:15
  • \$\begingroup\$ Your title question, and your final question don't match. \$\endgroup\$ Commented Sep 24, 2016 at 17:37
I have never heard of the expression "functionally complete" before so I looked it up.
From the point of view of digital electronics, functional completeness means that every possible logic gate can be realized as a network of gates of the types prescribed by the set. In particular, all logic gates can be assembled from either only binary NAND gates, or only binary NOR gates. Source: Wikipedia, Functional completeness.
As an example, every logic gate can be assembled using the set {OR, AND, NOT}. We can do better than this though. Just using the set {NAND} we can create all the others:
Figure 1. Using only NAND gates we can construct NOT, AND and OR. NAND and NOR can be created by adding a NOT. NOR, XOR, XNOR and others can also be created.
In this sense the set {NAND} is functionally complete. The set {NOR} is similarly functionally complete. As a result these were most common gates used in discrete logic and also had the advantage of very short propagation time.
See Wikipedia's NAND logic and NOR logic for more info.
Lo que quiere decir , es que si usted armo correctamente la funcion booleana sin simplificar , al simplificarla correctamente con el algebra de boole usted va a obtener la misma función con las mismas características de la primera .
What that means is that if you armo correctly the function boolean without simplify , to simplify correctly with the algebra boole you are going to obtain the same function with the same characteristics of the first (functionally complete).
    \$\begingroup\$ Google gives a better translation than you do - but you do not address the question. Answers are supposed to be in English, I think (although I was unable to find a reference to confirm this). \$\endgroup\$ Commented Sep 24, 2016 at 17:18
