How can I make a single via or a hole with different sizes at different layers?
for example, I have a 4 layer board and I Need 4mm hole size from layer 1 to layer 2 and 3.5mm size from layer 2 to layer 4.
Thanks in Advance.
Thanks in Advance.
You can do that by placing two different vias on top of each other and adjusting the start and stop layer. Just be careful about how you're going to communicate this to your manufacturer.
NOTE: It looks wrong in 3D viewer, but the gerber data is correct.
