I need to plot Smith chart, having frequency, VSWR, reflection coefficient and phase. I'm aware there's smithchart
command in matlab and as an argument I should use reflection coefficient, but my chart looks not as it should (below the chart you can see my rho values):
As far as I know, as an output I should get something similiar to this:
So my question is: is there any program that will help me with this task, using values that I mentioned in the first line? So far I've found something called Smith
, but it would be rather tiresome to manually add dozens of points. Still, if it's the easiest way to plot Smith chart, I'll go with it.
