I am not just an electrical engineering noobie, I'm an electrical engineering dummy. (No, you can't use me for testing your newly designed electric chair.) What I need is a simple, direct answer, to a very narrow question. I realize that such an answer may not be available. If that is the case, please feel free to say so.
Here is my understanding:
If you were to plot S11 of a basic electronic component (e.g. capacitor, inductor, resistor) on a Smith Chart, you will get a curve that represents the impedance of that component as it changes with frequency. Impedance is R + jX, where X represents the reactance (inductance/capacitance) of the component. At any particular point along the S11 Curve, the Smith chart will display R + jX of the component at a particular frequency.
For commercially produced inductors, manufacturers list a nominal inductance figure, e.g. 100 uH. They will (or should) also tell you the frequency at which this value was obtained, since inductance of anything is not constant over a range of frequencies.
Here is my question:
In the case of an inductor which the manufacturer lists as 100 uH at 100 kHz, looking at the S11 plot, at the point where the frequency is 100 kHz, should the X, in R + jX be the same as the (nominal) inductance of the inductor?
I understand there are many factors that will affect the accuracy of such a measurement. Insofar as it is possible, assume that care has been taken to reduce these factors to a minimum, and that, none-the-less, any such measurement will be accompanied by some percentage of error.
  • \$\begingroup\$ I would expect it to be so. \$\endgroup\$
    Jan 10, 2020 at 15:00
    \$\begingroup\$ "should the X, in R + jX be the same as the (nominal) inductance of the inductor?" X is the inductive reactance of the inductor at that specific frequency, not it's inductance \$\endgroup\$
    – NMF
    Jan 10, 2020 at 16:20
  • \$\begingroup\$ NMF - So your direct answer to my question would be "No." Is that correct? \$\endgroup\$ Jan 10, 2020 at 23:22
  • \$\begingroup\$ @Gordon Shephard - if your question is effectively 'is an inductor's inductance the same as its reactance when plotted on a Smith chart' , then no, it isn't. \$\endgroup\$
    – NMF
    Jan 10, 2020 at 23:31
  • \$\begingroup\$ @NMF - Yes, that was exactly my question. Thank you for your response. Believe it or not, it is helping me to understand. \$\endgroup\$ Jan 10, 2020 at 23:43
4 Answers 4
You are confusing inductance with reactance. The inductance is set by the component and is constant. The reactance of that component changes with frequency.
S-params are often measured in a 50 ohm environment. The impedance of 100UH at 100KHz will be about +j63 ohms, so you should be rather close.
The equipment usually has a "normalization" mode, where open circuit and short circuit performance are digitized and then used to correct the desired measurement.
Since 1 picoFarad at 100KHz is -j1.6 MegaOhms, the undocumented (residual) electric field errors will be small.
I suspect that the best model for an inductor at its rated frequency is a series connection, so \$R_L + j X_L\$ is probably best.
Even if it isn't, any errors in representation are going to be less than the inductance tolerance of a typical inductor -- and if you've got an atypical, super-precise inductor, then it should come with atypical, super-detailed specifications.
Reactance which is $$ X = j 2 \pi f L $$ will change versus frequency, the inductance will not
