Robot Controller Problem
A computer needs to control a robot, where the computer sends the following commands:
- Do nothing 00
- Turn right 01
- Turn left 10
- Move forward 11
You have to design a circuit that accepts these commands and sends the robot the following signals
- Do nothing 000
- Turn right 001 010 011
- Turn left 101 110 111
- Move forward 100 100
So they respectively take 1,3,3 and 2 clock cycles. Until the current command is completed, don’t take a look at the next input from the computer.
Input
- Clock Pulse CP
- Input Available IA
- Input Command C0, C1
Output
- Output Available OA
- Output Signal S0...S2
Is the state Diagram correct. What would be output values? Or Output is not needed? And What Information is helpful to know in advance for building this project?
000
state for both the "do nothing" command and for the "no command received" idle state. You need to separate this into two separate states. Remember, you need to include theIA
signal in your list of inputs, and theOA
signal in your list of outputs. \$\endgroup\$
