I want to send my board to production however i am not sure a component's actual sizes because there is not enough information on its datasheet. I put its image and the necessary dimension "x".
This is the datasheet information;
This is the necessary size for me, shown by "x".
I could not find "x" from datasheet drawing that i put above. This is a "Vectronix DMC-pico" digital magnetic compass. I am considering to send for prototyping as versions because i am not sure actual dimensions. I mean i want to prepare 10 versions on a single board like panelizing for protoype on Altium, however i intent to draw different size of "x" as 0.85 mm, 0.90 mm, ... , 1 mm, 1.05 mm for a more precise result. I tried to do this on Altium but it allows me panelizing the same board only. Do you know a way that i can put different versions on a single panelized board on Altium Designer?
Thank you
