I'm currently working on a project that features a Blackfin BF592 processor (datasheet).
I'm trying to interface this DSP with a stereo audio codec (datasheet).
Originally, I assumed that this audio codec would have some high frequency clock signal (i.e. frequency much higher than the sample rate) that would likely be fed from some oscillator circuit. I believed that this input clock would be divided as necessary to get a lower clock signal (e.g. 44.1kHz).
However after looking through the datasheet of this codec, it appears that the expected clock signal inputs are meant to be 'exact' and relatively low frequency (i.e. 44.1kHz-ish). And because this chip is a delta sigma codec, it actually expects two sample rate related frequencies: the actual sample rate clock, and then a multiplier of the sample rate clock to achieve proper oversampling.
Because I plan on sampling at 44.1kHz, with a oversample rate of x32, I will need two clock inputs: 44.1kHz and a 1.411MHz.
So my question: is it standard practice to use a DSPs internal timers to generate these signals? Or would it be more common to have a dedicated IC generate these two signals?
