I have a wave with ~ <10% modulation. Is there any way to amplify the envelope of a signal at the envelope demodulator end? You can barely make out the envelope in the image below but I think I need to amplify this otherwise the diode will be in an "off" position and it doesn't demodulate the signal.
This is the output of my envelope detector using the above waveform as the input
