I've just starting learning electronics. I've been using Autodesk Eagle for a little while now since it runs on Linux and seems to be pretty full featured. I like that you can easily design a circuit schema, layout PCB, and then order the PCB and parts. However, it seems to be missing a simulator which I really need. Searching online it seems that there an add-on simulator called PCBSim. It looks very cool, but the pricing is very high and as a hobbyist, I just cannot afford it.
Does Autodesk Eagle have any other, more moderately priced, add-on simulators? Did I miss anything with Autodesk Eagle's built-in functionality when it comes to circuit simulation? Should I be looking at other options other then Eagle? I've tried running LTSpice via wine, but it's been buggy.
Thank you
