Is there a way to automatically deduct PCB and/or chip design from formal problem specification of a problem (task) which supposed to be solved on a PCB/chip?
I'm currently implementing solution with OpenCL to be run on GPGPU in conjunction with CPU. To decide which part of an algorithm must be run on CPU and which on GPU I had to manually calculate speed of sorting on CPU and GPU and divide by speed of GPU <-> CPU communication.
All sorts of such problems, I think, can be solved automatically by applying of problem description upon hardware specification. Googling all of these brought me to pretty complicated and abstract topic of formal methods where LOTOS seems to be one of them. I learned a little bit of electronics and know that in-circuit electronic processes and components are very well mathematically defined and deterministic, so automatic PCB/chip layout must be able to be deducted from problem description. But I can't find any working tools/libs which can already do it.
I wonder if there is already working solution of how to do it?
P.S. Problem I'm trying to solve is about ~50 lines of somewhat close-to-machine specification, but I had to write already ~5000 OpenCL/C++ code to run the solution upon a device which at first glance is at least 10000(!) times less effective (speed*power-wise) than analog ASIC would be. I feel like I wanna cry :(
Somewhat close task specification of my problem in C-like pseudocode:
[declarations]
struct A { float Temp; float Value };
A Mem[ MEM_COUNT ];
A Cur[ CUR_COUNT ];
[process #1]
A S;
S.Value = getCurrentInputValue( attachedCamera/Mic/textFile/etc. );
S.Temp = 1;
Cur[ end ] = S;
for each C in Cur:
C.Temp += 1 - mod( C.Value - S.Value ) / C.Value;
approximately sort Cur by Temp;
[process #2]
A C = Cur[ 0 ];
for each M in Mem:
float sum = 0;
//farthest set is defined as each (MEM_COUNT / FARTHEST_COUNT)'th A starting from M
for each farthest of M:
sum += farthest.Value / FARTHEST_COUNT;
M.Temp -= mod( sum - M.Value );
[process #3]
A M = find M with the most Temp from Mem[];
outputValueToAttachedPin( M.Value );
And I would like to tweak MEM_COUNT, CUR_COUNT and FARTHEST_COUNT to see the resulting speed/price/power/etc. As I know, today's CPUs designed so that a program needs to do ~300 operations per every memory access, but in algorithm above it goes up to FARTHEST_COUNT accesses per operation. So, ASIC would be 300*FARTHEST_COUNT times more efficient?
