Im building a VGA (640x480@60Hz) adapter for my homebrew project but i dont have enought memory to store a framebuffer. Since im using 8 bit memory i plan to do 8 bit color, but 8 colors would be enought for my project.
How is the most efficient way to implement a character mask (8x8 pixels) using only memory and TTL? I was thinking about using a memory bank (6264) to store the character mask, another bank linked to that to select wich mask i want to use in a sequency using binary counters. Then using a PISO Shift Register (74166) at 25MHz to feed a multiplexer (74157) that selects background or foreground color stored at another memory bank. But this seems overcomplicated.
Since only the 74166 and the 74157 would be running at 25MHz i can get off with HC ones? Or better to run with another model (they are harder to find here).
I want to avoid FPGAs. Use only TTL, SRAM and microcontrollers.
