I know, another question about crystal capacitor values.
I would like to use this crystal in the 20 MHz version to clock an ATmega1284.
According to the crystal's datasheet, it has a load capacitance of 20 pF.
Using the formula \$C = 2(C_L - C_S)\$ and assuming a stray capacitance of 2 pF or 5 pF, I get a value for each capacitor of 36 pF or 30 pF, respectively.
However, this is outside the recommended range for the capacitors of 12-22 pF according to page 46 of the ATmega1284 datasheet.
So, can I even use this crystal, and if so, with what capacitors?
It will probably work with 22pF capacitors, however the frequency will be a bit off (high). Maybe 50ppm or 75ppm, not enough to worry about the maximum frequency of the MCU.
Better to buy a part that is calibrated with a lower load capacitance.
  • \$\begingroup\$ What would happen if I used 36 pF? \$\endgroup\$ Commented Jan 11, 2018 at 2:06
  • \$\begingroup\$ Might have trouble starting when cold or hot, things like that. \$\endgroup\$ Commented Jan 11, 2018 at 2:07
  • \$\begingroup\$ If I were to use either 22 or 36 pF, which would you recommend? (This is for a hobbyist project. Not frying my chips is my main concern.) \$\endgroup\$ Commented Jan 11, 2018 at 2:10
    \$\begingroup\$ Suggest 22pF... \$\endgroup\$ Commented Jan 11, 2018 at 2:11
    \$\begingroup\$ As Microchip says: Care should be used in selecting values of (load capacitors). Large values increase frequency stability but decrease the loop gain and may cause oscillator start-up problems. \$\endgroup\$ Commented Jan 11, 2018 at 3:20
They are implying you should choose a part with low load capacitance and not 20pF. This also helps reduce power consumption.
A=Series
E=10pF
G=12pF
U=13pF
L=18pF
M=20pF
N=22pF
Q=30pF
R=32pF
S=33pF
