The picture was taken off an equipment we are trying to connect to. Unfortunately the connector type was not specified in user manual.
The closest one I can find based on shape is molex 4 pin female connector, or 4 pin peripheral connector used to send power to CD/hard drive in desktops.The difference is, molex connectors have flat sides, while the socket in picture has curves around each pin.
Could anyone offer some clue?
    \$\begingroup\$ Pluggable terminal block. Probably something like one of these. \$\endgroup\$
    – brhans
    Commented Jun 11, 2019 at 19:40
6
Thats a terminal block header probably the same one shown below:
Source: https://www.digikey.com/product-detail/en/on-shore-technology-inc/OSTOQ045451/ED2830-ND/1588283
The terminal block plug can be found below
Source: https://www.digikey.com/product-detail/en/on-shore-technology-inc/OSTTS04515A/ED2863-ND/1588621
  • \$\begingroup\$ Out of 3 different answers this answer shows the PCB mount and correct pin diam. +1 for being a good component Eng. with attention to details. \$\endgroup\$
    – D.A.S.
    Commented Jun 11, 2019 at 21:17
    \$\begingroup\$ the actual component is more likely the following one judging from the two mounting holes: digikey.com/product-detail/en/phoenix-contact/1776524/… \$\endgroup\$
    – Zhiyong Li
    Commented Jun 11, 2019 at 22:09
5
That is a Camdenboss CTBP9350/4 (or equivalent). The mating plugs are:
  • CTBP9200/4
  • CTBP92VG/4R
They are available from all major distributors (Farnell, RS, Digikey, Mouser, Arrow, etc..).
    \$\begingroup\$ thank you so much.Have been searching for it the whole morning. Remember seeing them here or there, but the name always evades me. \$\endgroup\$
    – Zhiyong Li
    Commented Jun 11, 2019 at 19:43
  • \$\begingroup\$ My pleasure, we use a lot of them on control equipment. Customers love that you can wire them, then connect them. As opposed to standard screw-terminals which can be awkward. \$\endgroup\$
    – Cursorkeys
    Commented Jun 11, 2019 at 19:45
These connectors are most known from the Phoenix Contact Combicon family.
The shown socket mates with MSTB 2,5 HC/ 4-STF (1912090), however the metal plating inhibits the locking screws. So use MSTB 2,5 HC/ 4-ST (1911871).
That is assuming it's 5 mm. If it's 5.08 mm then add "-5.08".
However with a 4 pin you can just use more force...
Or get any of the other terminations they offer, they have a lot of choice. (eg: straight/angled or cage/spring)
