I am try to understand how to read data from current transformer circuit. As reference i am reading on this 2 articles: Article1 and Article2. I do not have easy access to oscilloscope which make it a bit harder for me to visualize.
Here is the circuit that Article one and two uses. (PS i am assuming the version where the burden resistor is built in to the sensor already)
What is the purpose of the Equal value resistor voltage divider and the capacitor? How would i compute the resistor and capacitor value?
what would be the reading if probes are directly connected to JACK A and B
The resistor divider is used for making a reference voltage. When no voltage difference is present between A and B, you get half of Vcc on the analog pin - say 1.65V. When the voltage difference A-B is positive you get more than 1.65V on analog pin, meanwhile when voltage A-B is negative you get less than 1.65V.
Between A and B you have to connect a burden resistor, then a CT.
Leave it the same. If it works for others, it will work for you, also.
Don't quite understand this question.
  • \$\begingroup\$ What would happen if i directly read the analog pin on Jack A and connect Jack B to ground? \$\endgroup\$
    – Jake quin
    Commented Oct 16, 2019 at 13:53
