I've read that Sziklai is prone to high frequency oscillations due to its feedback loop. I can't figure out where this feedback loop actually is. It should be obvious but I haven't understood this concept.
\$\begingroup\$ There's exactly one loop in the picture :) ! but, you won't see the temporal behaviour if you assume the transistors to be perfect, so add parasitic capacitances between all your transistor elements. \$\endgroup\$– Marcus MüllerCommented Dec 31, 2019 at 21:44
\$\begingroup\$ Thanks for the reply. Can you expand it? Where is the input and where is the output of that loop? Why should I add parasitic capacitances? \$\endgroup\$– Lucky-LukaCommented Dec 31, 2019 at 21:46
\$\begingroup\$ a loop is a loop and hence doesn't have an in- and an output. I explained why you need to think about the parasitic capacitances: otherwise there would be no temporally changing behaviour. \$\endgroup\$– Marcus MüllerCommented Dec 31, 2019 at 21:50
\$\begingroup\$ All Emitter Followers are susceptible to parasitic resonance on sharp edges due to unity gain feedback >1 when driving cable capacitance. Avoidance by adding ferrite beads or better a small series R. \$\endgroup\$– D.A.S.Commented Dec 31, 2019 at 22:25
\$\begingroup\$ The emitter resistor R2 introduces a negative feedback (the so-called 'emitter degeneration'). \$\endgroup\$– Circuit fantasistCommented Dec 31, 2019 at 22:41
I have illustrated much of what was said in the answers and comments above and expanded it by some of my thoughts.
1. Compound transistor. The n-p-n and p-n-p transistor connected in this way form a compound n-p-n transistor T (in blue). We can think of this combination of as a "weak" n-p-n transistor "helped" by a stronger "brother" or, in terms of equivalent electrical circuits, as of two current sources in parallel. With a little more imagination, it can reminds the Howland current pump where another "helping" current source is connected in parallel to the the imperfect input current source... like an INIC negative resistor...
2. "Emitter" follower. Once accepted it is just a single transistor, we see that here it is connected in the well-known circuit of an emitter follower. It copies, by means of the negative feedback principle (the little block diagram), the input voltage VIN on the load RL as follows:
The output voltage VE is compared with the input voltage in the possibly simplest way - by connecting the two voltage sources contrary in series. So their voltages are subtracted according to KVL... and the result is applied to the amp input (the base-emitter junction). Note the compared voltages are grounded while the input, where the result appears, is floating. Thus the subtractor (in yellow in the block diagram) is made at no cost; it is just the loop... a piece of wire...
When we change (e.g., increase) the input voltage VIN by moving the potentiometer slider, the Sziklai transistor T reacts to this "input disturbance". It begins increasing its "emitter" current through the load RL and, accordingly, the output voltage VE across it, until reaches the equilibrium (with VBE below VIN). This is, roughly outlined, the mechanism of this kind of negative feedback called "emitter degeneration".
3. Active diode. Now let's try to see another (internal) negative feedback. Remember the so-called "active diode" that exploits a dual kind of negative feedback. There the output (collector-emitter part) is connected in parallel to the input (base-emitter junction); this is simply a transistor which collector is connected to the base.
So we can note that in the Sziklai configuration, there is such a connection (negative feedback network) between the collector and base of the output transistor... and this is the collector-emitter part of the first transistor. It turns out that when the input transistor is close to saturation, it will act as a feedback network (like a piece of wire) that conveys the collector voltage variations to the base. As a result of this negative feedback, the output transistor will be never saturated (will be ever in active mode).
Of course, in this emitter follower application, the input transistor is never saturated... but in other applications where its emitter is firmly connected to fixed voltage (common-emitter stage), it can be saturated...
2\$\begingroup\$ Now that i think about it...I remember you... looking at your nice drawing. You have already answered a question of mine elsewhere. Thanks for your time. eevblog.com/forum/beginners/… \$\endgroup\$ Commented Jan 1, 2020 at 15:38
1\$\begingroup\$ This is a conceptual picture only. Add RL to the "blue circle" and everything will be fine... \$\endgroup\$ Commented Jan 1, 2020 at 16:11
1\$\begingroup\$ @ Lucky-Luka, Sorry for the mistake in my previous comment. This is because I prepare answers to several questions at once and here is the result. I have corrected and placed it here as I could not delete it. I happy to see you here! It would be great to establish such cross-links between sites... I would happily link to many of my (free) educational resources on the web, but the StackExchange policy does not allow that. So I have to rewrite what I created in new words... which also has some advantages... giving a rise to new ideas... \$\endgroup\$ Commented Jan 1, 2020 at 16:26
1\$\begingroup\$ You wrote "When we change the input voltage VIN by moving the potentiometer slider, the Sziklai transistor T reacts to this "input disturbance". It begins increasing its "emitter" current through the load RL and, accordingly, the output voltage VE across it, until reaches the equilibrium (with VBE below VIN). This is, roughly outlined, the mechanism of this kind of negative feedback called "emitter degeneration"." Does Vbe change in the meantime? I think it should. \$\endgroup\$ Commented Jan 3, 2020 at 13:00
1\$\begingroup\$ You wrote "Now let's try to see another (internal) negative feedback. Remember the so-called "active diode" that exploits a dual kind of negative feedback. There the output (collector-emitter part) is connected in parallel to the input (base-emitter junction); this is simply a transistor which collector is connected to the base." Can you point out which transistor in your design you are referring to please? \$\endgroup\$ Commented Jan 3, 2020 at 13:02
¨Q3 pushes current through R2 about the current gain of Q3 times the base current of Q3.
The base current of Q3 is the collector current of Q6, which is about the current gain times the base current of Q6.
The base current of Q6 depends on the voltage difference between the base of Q6 and the emitter of Q6.
The voltage at the emitter of Q6 depends on how much current Q3 pushes through R2. This is how the collector current of Q3 affects itself through two transistors, the feedback loop. At low frequencies the feedback is negative, the voltage at the collector of Q3 will follow what's inputted to the base of Q6.
The application idea of this circuit is to make a boosted emitter follower (search for emitter follower, it's one of the most basic transistor applications). A single transistor emitter follower is enhanced by adding the other transistor, in your case the extra component is Q3. The result is like a single transistor emitter follower which contains a very high current gain transistor, the effective current gain can be thousands or tens of thousands.
Unfortunately the non-ideality of the transistors make the circuit behaviour complex. An example:
The output voltage at NODE2 should follow the input voltage with about 0,6V difference. The input voltage (blue) drops from +6V to +4V as a -2V step. One could expect that the output voltage (yellow) should drop as much but with a ramp due the slowness of the transistors. Instead of it one can see a short peak upwards before the expected drop.
I have seen the same with oscilloscope, too. I must admit that applying fast pulses was a whim with no original intention to amplify fast pulses with multistage feedback amplifiers, so this example is theoretical only.
High frequency oscillations occur if the transistors can handle so high frequencies that the wiring (inductance, capacitances) and junction capacitances inside transistors together cause so much phase lag that the feedback starts to be positive. That can happen easily if there's long non-matched signal cables or the circuit is built on a breadboard.
An example:
The curve is the voltage over the resistor. The circuit oscillates at the resonant frequency of the LC circuit. There's no intentional RF resonant feedback circuit, only something which is possible with long input signal wires. The oscillation amplitude doesn't build up to full supply voltage wide swinging because the loss in the NPN transistor BE junction is an effective amplitude limiter for the resonant circuit.
ADD due the comments(which started to turn to attempts to find errors and partially deleted for that reason)
Darlington emitter follower is also a 2 stage feedback amp. The feedback route there isn't obvious like in Sziklai pair where a wire exists from the load to the emitter of the NPN transistor. The emitter can be seen as the 2nd input of the 1st amplifying stage.
In emitter follower the output terminal is the same as the 2nd input of the transistor, no wire is needed, but the effect is = feedback as others try to show with equations. The input current depends on output voltage. Darlington pair emitter follower has 2 emitter followers cascaded. The output voltage affects also to the input current of the 1st transistor because that depends on the voltage at the base of the 2nd transistor which is the sum of the output voltage and voltage drop in the BE junction of the 2nd transistor.
With reactive input circuit a darlington pair emitter follower oscillates like the Sziklai pair:
\$\begingroup\$ Thanks a lot for this detailed answer! Does this internal loop happen with a Darlington pair? \$\endgroup\$ Commented Jan 1, 2020 at 13:30
\$\begingroup\$ No...I cannot agree to the mentioned conclusion that there would be a systematic "internal feedback loop". This is not correct. Of course, each electronic part or circuit cotains unwanted parasitic feedback loops - but I don`t think that this effect is relevant to the question. The only relevant feedback effect is caused by a resistor in the common emitter path. \$\endgroup\$– LvWCommented Jan 1, 2020 at 14:08
\$\begingroup\$ Yes - why not? But the question was if there is a feedback effect - INTERNAL to the Darlington/Sziklay combination. With external reactive components each transistor can be turned into an oscillator. \$\endgroup\$– LvWCommented Jan 1, 2020 at 14:33
\$\begingroup\$ @user287001...please, can you explain a bit more? What is a "dedicated feedback wire"? The question is: Without any external components, is there any (hidden ?) internal systematic feedback loop? If yes, where is it? The questioner has shown a circuit with an emitter resistor and was asking "where is the feedback effect"? And the only answer is: This resistor causes feedback. \$\endgroup\$– LvWCommented Jan 1, 2020 at 14:56
\$\begingroup\$ Between the emitter of Q3 and the collector of Q6 is the B-E path of Q3....and this is a "dedicated feedback wire"...??? Sorry, but his sounds a bit weird... \$\endgroup\$– LvWCommented Jan 1, 2020 at 15:52
Sziklai pair (also known as Complimentary Feedback Pair or CFP) is the simplest (and probably most misunderstood) form of current-feedback opamp.
Q1 is the input stage (ie, the "substractor" in the usual feedback loop schematic). Its base b1 is held at input voltage v(b1) by whatever circuit drives it.
Current feedback occurs through Q1. If output voltage v(out1) is too low relative to input voltage v(b1), Q1 collector current increases. If v(out1) is too high, Q1 collector current decreases. So our "input stage" does have one positive input (Q1 base b1), one negative input (Q1 emitter out1), and an output (Q1 collector current). It also has one Vbe offset voltage built-in, but that only matters at DC, not for analysis of AC feedback loop stability, nor for calculating input/output impedances, etc.
The positive input is high-ish impedance and the negative input is low impedance, which is one defining criteria of a current feedback "opamp". Voltage-feedback opamp, by comparison, would have high input impedance on both inputs.
In small-signal, Q1's output (its collector current) is \$ g_m ( v_{b_1} - v_{out_1} ) \$ with gm being Q1's transconductance.
Q2 amplifies Q1's collector current according to its current gain hFe and outputs this current at node out1. Thus the output of this two-transistor circuit is a current which is the sum of Q1's Ie and Q2's Ic.
Then, the load R11 converts output current into an output voltage, and this closes the loop and is connected to the load.
So our feedback loop is:
v(out1) -> current feedback through Q1 -> Ic(Q1) -> Q2 -> Ic(Q2) -> load -> v(out1)
Note I added resistor R12 which increases current through Q1. This increases its gm (thus loop gain) and makes it faster to turn Q2 off.
Now, did I just say that the negative input of our input stage (Q1's emitter) takes voltage as input while the thing is a current feedback opamp? Sure! So let's mentally split Q1 into two parts: on the schematic below Q1 is now an ideal bipolar transistor with infinite transconductance, infinite gain, etc, and R13 is its internal emitter resistance which is 1/gm, or about 13 ohms at 2mA Ic:
Then it becomes easier to see that feedback is done via current through R13. But R13 does not exist as a resistor on our printed circuit board, it is inside the transistor, just like node "e" on this schematic. The actual negative input pin of our input stage is Q1's emitter, which means node out1, and it takes voltage as input.
This circuit is hilariously simple and headache inducing.
Note that you can add an emitter resistor to Q1 if you want. It will be in series with its internal emitter resistance and thus decrease its gm, which lowers loop gain, and the resistor has the same role as the feedback resistor used to wire a current-feedback opamp as a unity gain follower:
(Note the opamp in this diagram has the same symbol than a voltage feedback opamp, which does not require the resistor, which can be confusing).
...and if you want a gain of 2 with your current feedback opamp, you can do it too:
R11 is the load, R14-R15 is the feedback network, "e" is the negative input of the "opamp"... and output voltage v(out1) is about twice input voltage (modulo a lot of offset).
And... Could we turn this into a voltage feedback opamp? Sure, we have to add a buffer to make the negative input (which now is the base of Q3) high-impedance. The one on the left looks like a crude opamp, the one on the right has huge offset but uses the same voltage feedback principle.
Edit for LvW:
This is a simplified current feedback opamp with a quasi rail to rail (common emitter) output stage. It is only a "practical" circuit for audiophiles since it has been stripped of lots of useful things like having decent open loop gain, compensation, etc... and it has no bias control so thermal runaway would occur unless the output transistors are lateral FETs 😁
Q4/Q5 bias the input stage Q1/Q3 which runs in current feedback via resistor Rf. This is the same "diamond" input structure as lots of current feedback opamp designs. Then Q2/Q6 provide current gain. A real opamp with a real common-emitter rail to rail output stage would of course be more complicated but this is basically the idea: Q1/Q2 and Q3/Q6 are two Sziklai pairs. Removing one of the pairs, for example Q3/Q6 returns to the original sziklai and makes the output unable to sink current, but it is still a CFB opamp...
1\$\begingroup\$ I fully support your reasoning and admire the way you put it. I myself have the same idea about the so-called "current-feedback amplifier" (CFA) and have repeatedly defended it in other forums on the web... but have not understood. I would be happy to link to these resources... but this would be interpreted as a self-promotion with negative consequences for my contribution here. It's great that there are people like you with such a creative thinking... \$\endgroup\$ Commented Jan 1, 2020 at 15:41
\$\begingroup\$ Thanks! Sure, send a link, that'll be interesting! \$\endgroup\$– bobfluxCommented Jan 1, 2020 at 15:43
1\$\begingroup\$ Everything I have understood and explained to my students and web readers has been uploaded to the web. I am used to using these resources in the discussions I have on the web by linking to them. But, as I explained below, this was not allowed here. And at the beginning of the month, my account was suspended for a week. So now I am careful and avoid putting such links... Regarding the CFA, it really deserves a special attention... \$\endgroup\$ Commented Jan 1, 2020 at 16:07
2\$\begingroup\$ Since i prefer reading things on paper I've printed this answer 3 times up to now. Who knows if a 4th print will come? :) \$\endgroup\$ Commented Jan 1, 2020 at 17:37
1\$\begingroup\$ I suspect that this circuit is called a CFA because of the fact that the "error" current at the input stage is "mirrored" and further processed by the circuit. But if we look at the circuit from classical defined a feedback theory point of view. This topology of a circuit is a voltage-series feedback amplifier (series-shunt). \$\endgroup\$– G36Commented Jan 1, 2020 at 17:55
As a basic example, the picture shows the feedback loop caused by an emitter resistor RE which realizes current-controlled voltage feedback (and is one of the various proofs for voltage-control of the BJT).
This block diagram is nothing else than a simple visualization of the basic formulas for the voltage driven npn BJT with the transonductance gm=d(Vbe)/d(Ic). Note that this visualization assumes Ie=Ic - however, an extension is possible subtracting Ib from Ie. But this would not change the feedback loop.
The Darlington pair as well as the shown Sziklay combination can be be treated as another single npn BJT - of course, with modified parameters.
\$\begingroup\$ Does that feedback loop represent a common emitter amplifier, right? Btw isn't gm=d(Ic)/d(Vbe) \$\endgroup\$ Commented Jan 1, 2020 at 14:51
1\$\begingroup\$ It represents a common emitter amplifier with emitter degeneration (negative feedback) caused by RE. For RC=0 it represents a common collector stage (emitter follower). In this case, the output is identical to Ve. \$\endgroup\$– LvWCommented Jan 1, 2020 at 15:03
1\$\begingroup\$ Note that the given expression for Vout/Vin (classical gain formula for a gain stage with emitter degeneration) can be derived directly from the block diagram - using Blacks formula for negative feedback. This proofs the validity of the block diagram. \$\endgroup\$– LvWCommented Jan 1, 2020 at 15:10
