I've got SN74LS93N chip that I am trying to get to work. I connected it as per datasheet but instead of counting, all outputs are flashing with clock signal...
I read online and found advice to connected all unused pins to ground (not on this video) but the result is the same... Am I doing something wrong?
Thanks pete
EDIT:
Posting how I connected the circuit. I used Falstad - Hope it's okay..
EDIT2:
I built the clock as per Ben Eater's instructions from YT. Schematics below
