From Sedra-Smith:
Another limitation on the operation of op-amps is that their output current is limited to a specified maximum. [...] This, of course, has to include both the current in the feedback circuit as well as the current supplied to a load resistor. If the circuit requires a larger current, the op-amp output voltage will saturate at the level corresponding to the maximum allowed output current.
The meaning of the paragraph is clear, but I still don't get why op-amps have such a limitation on the output current. How can you deduce that from the internal circuitry of an amplifier? For example, if we consider the two-stage CMOS op-amp below, is there a way to calculate the maximum output current?
