What are those 1 4
and 2 3
on both sides of the button? They look like having connected to same places at both ends, it looks like redundant cable to me.
So, what are they representing?
What are those 1 4
and 2 3
Tactile switches usually have four pins, with pin pairs already connected to each other. Very often you'll see that the switch closes contact between the pins on a particular side.
Since pin numbering is typically done on alternating sides, but the contact is done between adjacent pins, you can have pairs [1,4] and [2,3] electrically connected.
Here is an excerpt from a common tactile switch datasheet (C&K PTS645):
The schematic (top right corner) shows a slightly different arrangement where the pairs are [1,2] and [3,4].
You can use a switch with either arrangement, just be sure you know which pins are electrically "normally closed" and which are "normally open" by examining the datasheet before you solder.
I was induced to post this answer here because another question I started to answer was closed as a duplicate of this one.
There are two other things to consider regarding the two pins on each side connected together that are not mentioned in other answers and or comments.
Those are pin numbers.
It's useful to have them on the schematic to verify that the correct pins of the physical part will be connected to the correct places in the layout.
1 4
and 2 3
pairs the ones which are internally connected? Is this numbering a standard for tactile switches?
