Having trouble making a Buck converter using two complimentary switches in LTSpice. I've got everything laid out exactly as perscribed, but when I run I get the following error:
"Can't find definition of model "SW""
I've put the model for each one right there, so I've got no clue why it wouldn't know what to do with the switches. If anyone has any ideas on how to correct that please let me know, thanks.
C2
is completely useless, unless you're adding some sort of series resistance betweenV1
andC2
(either add a new resistor, or addRser=<...>
toV1
). Or addRser
toC1
, that will also do, if you can live with that zero. \$\endgroup\$
