I just started learning circuit simulation using LTspice. I want to try a basic circuit such as buck converter for practice. I looked online for formulas to find the values of the required components, but none of the websites really specify which MOSFET they used. I looked through the list of PMOS and NMOS and I don't really have any idea which MOSFET is suitable and which MOSFET is not.
For example, if I wanted to build a 12V-5V buck converter, which MOSFET should I use?
sw
symbol) in LTspice. Then, once you get going and understand the operation of the circuit better, you can swap it out for an actual MOSFET. \$\endgroup\$.model
line with the specs from the datasheet. Btw, good distributors have powerful parametric search functions, so you have to look into datasheets only as confirmation. \$\endgroup\$
