I've been asked to reattach the positive cable that got ripped with the pad from a board given that I own a soldering iron. It seems simple enough to just jump it from a trace.
Scraped a bit of the mask off from the pad space at P1, yet I don't get anything at all while measuring for continuity from the negative cable to the exposed trace.
The whole board is covered in some resin if that helps.
As I see it the big traces starting in P1 are clearly separated so those should be the negative and positive sides so the magic pixies should go from one side to the other, but they seem real lazy.
What am I not understanding?
Edit: this board is for showing battery level on some boat, theres a counter soldered on the other side
