I am trying to reverse engineer and understand the following circuit found in an LED lighting controller.
The OUTPUT is basically a 12V supply where the polarity can be selected by the MCU (Q7/Q2/Q1 N-MOSFET gate inputs) - almost like an H bridge I guess. Strings of LEDs are connected to this output in alternating polarity.
When the Q7/Q2/Q1 N-MOSFET gates are low, the outputs are 12V/12V therefore 0V between them.
When the Q7 N-MOSFET gate is high, the outputs are 0V/12V therefore -12V between them.
When the Q2/Q1 N-MOSFET gates are high, the outputs are 12V/0V therefore +12V between them.
My question is, what is the point of the middle section (Q2 + zener diode) and why does it have separate MCU control (which always follows control of Q1). I imagine it is some form of protection?
Note: Q6/Q9 are P channel MOSFETs.
