I just wanted to ask you if I can use SN74154N as a library and, hopefully, it would be same size (pins, etc..) as my original component MH74154.
Also, what component would you recommend instead of MH7404 hex inverter in Eagle? It should also be the same width, pinout number and so on..
I want to use all of these components in my PCB project.
