I created the boost conveter in LTspice software, but when I try to run the simulation, there was an error message saying:
Fatal Error: In Missing node(s).
Can anyone help me out with the problem?
I suppose you wanted to add a node name (F4
), but you ended up placing a SPICE directive (S
). That's why the netlist shows Rload
to be connected between the nodes N003
and ground, instead of what is seen in the picture, OUT
. To correct that, delete OUT
, and IN
(same thing), and then add the proper naming: either with F4
, or with the small A right between the ground and the resistor, in the toolbar. Or from the menu, Edit > Label Net
Not a big deal, but you renamed the MOSFET's designator from M
to Q
. That's usually reserved to bipolar transistors, though nothing will happen if you rename it, LTspice takes care of it, anyway (see the M§Q1
entry in the netlist). Just so you know.
(TAB
cycles between the names) to notify people when replying in the comments, otherwise they will never know. Also, this is not very electronics related as much as it is LTspice related. There's a group dedicated for this. \$\endgroup\$
