I have a system that can only supply very low current > 10mA at 12v. It has one output that will pull high or low depending on if it is powered on or not. I have another device I would like to control based on that output, it has an up, common, and down. When connecting up and common it turns on, when connecting down and common it turns off.
I was originally going to use a 5 pole relay to do the switching from common to the respective up and down (NC: common -> down) (NO: common -> up) but because the system is such low current I can't trigger the coil on the relay.
Could someone point me in the right direction for doing this with transistors? I have a very very basic understanding but I have been using circuit lab to try to build such a thing that sends output1 low, output2 high when given a high input, and then when given a low input sends output1 high, output2 low but I haven't had much luck.
For further clarification I have a controller that has a 12v power supply capable of 10mA (current limited internally), it has a switched output that can do 12v at 2.5mA (again current limited internally)
I then have a system that has a floating (meaning I can bring the voltage up or down it's not ground referenced) and it has "common", "up", and "down" terminals. To turn it on you need to allow current to flow from common to up, to turn it off you need to allow it to flow from common to down. This system is also limited, and a perfect 1mA flows from common to either up or down when connecting it.
So these systems are very low current and protected.
I am thinking I need something like a NOT Gate and maybe a regular Gate if such things exist to pull "up" or "down" to "common" depending on if the input (output of the first thing) is high or low.
