8
A circuit with three capacitors and an open end at A:
I am a high school student. I am very confused by this example.
The circuit is open at end "A" as shown but still there would be some surface charges on the capacitor which is not connected in closed circuit. There would be surface charges on the wires so that the net electric field everywhere inside the conductors will be 0, but in the school textbook they say that current will not go towards an open end so we can treat those two capacitors which are connected in closed circuit to be in series combination. Also all the charges that are accumulating on one plate would come from the other plate connected in series.
In this way all the charge that leave from one end of the battery would enter into other end, but how is this even possible?
Charges are accumulating on wires also and on capacitor which have an open end but we are ignoring them. Why? If we don't ignore them then the capacitors would not be in series and also the charges leaving one end of battery and entering other would not be equal.
  • 5
    \$\begingroup\$ I'd recomment to break your wording in phrases, it's difficult to read. Anyway, this is a tricky question since usually you either a) ignore parasitics or b) compute parasitic effects. If you consider residual charges on wire you are considering parasitics, but at the same time you are ignoring leakage current in the capacitor and parasitic capacitance to the external ground. So IMHO the problem is not well-posed. I think your doubt are legitimate, ask your instructor \$\endgroup\$ Commented May 24, 2022 at 7:57
    \$\begingroup\$ +1 on what @LorenzoMarcantonio said. It's down to if you threat this as an ideal circuit or a real one with parasitics, such as stray capacitance via air. \$\endgroup\$
    – winny
    Commented May 24, 2022 at 8:12
    \$\begingroup\$ The pair of capacitors connected in the closed circuit are in series. It makes no difference to that statement whether the 3rd capacitor's terminal A is connected somewhere or not. Obviously it makes a difference to how you would analyze the circuit, but those 2 caps are in series no matter what you do with 'A'. \$\endgroup\$
    – brhans
    Commented May 24, 2022 at 10:07
  • \$\begingroup\$ @brhans, that's not correct. If A is connected somewhere (with a return path to the power source), then not all current that flows through the left capacitor must also flow through the right capacitor, and they are not in series. For example, we can't use the series capacitors formula to find the equivalent capacitance of the combination, or the series impedance formula to find the equivalent impedance of the combination. \$\endgroup\$
    – The Photon
    Commented May 24, 2022 at 15:27
  • \$\begingroup\$ "Why must the incoming and outgoing current in a battery always be equal?" -- because, like gravity, it's the law. \$\endgroup\$
    – ilkkachu
    Commented May 24, 2022 at 17:22
11
Unless this circuit is being operated with a voltage source with frequency in the megahertz or more, there's not much point in analysing what happens to actual charges here.
You can rely on Kirchhoff's Current Law to tell you everything you need to know about this circuit, and yes, it works for capacitors too. If you insist on talking about charges, let me assure you, that if one single electron enters one side of a capacitor, then another exits the other side. If that happens to the top capacitor in your diagram, you now have a greater charge density at A than before, and the change in potential that causes would simply push the electron right back in again.
Because current in equals current out, and because there is "infinite" resistance to current flow out of A, no current flows in that top capacitor, and you can consider it to be entirely absent. Consequently, all that remains is the other capacitors in series.
As far as charges entering and leaving the voltage source are concerned, one thing is certain; no electron that leaves that source can ever return to it "in person" because there are dielectric barriers in the capacitors, which the electrons cannot traverse.
This should tell you that the electrons entering the voltage source must already be present in the wire connected to it. I'm alluding to your idea that charges accumulate in wires, which is not the case. They are always there. Like when you switch on the tap in your bathroom, water emerges immediately, because water was already in the pipe. If the pipe was empty, sure, you would have to wait for the water to arrive from the tank, but that's not how electric current works. Charges are always present in conductors, it's simply not possible to "empty" them of charge.
What I just said is true, but capacitors seem to act differently. It is possible to remove charges from a plate, but as you do, more charges will be drawn onto the other plate as a result. The total quantity of charges on both plates of a capacitor doesn't change, but their distribution within, does. This is why I can say that if charge enters one capacitor terminal, then the same amount of charge must necessarily leave out of the other terminal. Current in equals current out, in accordance with Kirchoff's Current Law. All that has changed, really, is the distribution of charges on the plates of the capacitor, and no charge ever crosses the dielectric.
So, I reiterate, since by Kirchhoff's Current Law we see that no current can flow out of the capacitor to node A, no current can flow into that capacitor, and it can be disregarded. If for some reason charge made it out of the capacitor into node A, this would disturb the equilibrium of charge distribution within that node, and the resulting change in potential would simply cause the equilibrium to restore itself, pushing charge back into the capacitor.
Of course, charges are moving all the time, mainly due to kinetic energy which we call "heat", so what I am describing here is an "average" behaviour of trillions of charges. Sure a few might move upwards towards A, but they will displace another bunch back down again, so on average, there's no current flow.
So, ignoring individual charge behaviour, en-masse they behave in such a way that it is simply not possible for charges to enter anything without an equivalent quantity also leaving, which may or may not be the same actual charges. When you charge a battery, there are not more electrons in it now than there were before, they are simply distributed differently with the battery. Current in always equals current out, and that's Kirchhoff's Current Law (KCL) in a nutshell.
Edit: I'd like to say also that when people refer to "charge accumulating in a capacitor", that's misleading. Accumulation of charge on one plate results in an equal depletion of charge on the other, so there's no net accumulation; only a change of distribution.
Also, just to drive the point home, within a section of wire, there are a certain number of electrons which are mobile, and can participate in "electric current". That number doesn't change, whether current is flowing or not. When a million electrons are pushed in one end, a million are shoved out of the other end, the total number occupying the wire section never changing.
You should discard the notion that charge "builds up" anywhere, except under very particular circumstances. For example, a FET's gate may accumulate electrons, but that will simply expel electrons in the channel, forming a depletion zone. From the perspective of an observer outside this FET, though, KCL was obeyed, because those expelled electrons will manifest an equal charge flow out of the drain and/or source. In other words, even though individual devices may rely on some imbalance of charge distribution within them, their net charge content does not change. To the engineer outside, no imbalance would be visible, and no violation of KCL would occur.
  • \$\begingroup\$ but if you'll think logically, I am saying that there should be some surface charges on top capacitor because only that can change its potential which was initially considered to be 0 w.r.t infinite and finally let's say its "V" . ofcourse there wouldn't be any current leaving node "A" but charges can redistribute themselves to cancel the net electric field onto that top isolated conductor ,,,,,,I think you don't know much about surface charges and how it sets up in a circuit , I like to think in terms of electric fields and not just by considering voltages at different parts \$\endgroup\$ Commented May 26, 2022 at 5:32
  • \$\begingroup\$ @ArunBhardwaj you are right, I don't know much about surface charge \$\endgroup\$ Commented May 26, 2022 at 7:16
  • \$\begingroup\$ The ambiguous description of charge building up stems from the multiple definitions of charge that are (unintentionally) applied. I'd say it's correct to say that a capacitor is charged (like a battery is charged), but what's built up in there is energy. \$\endgroup\$ Commented Jun 3, 2022 at 11:49
  • \$\begingroup\$ Your remark about the electron re-entering the battery in person raises an interesting philosophical question. On the one hand, you are "obviously" right. On the other hand, as an indistinguishable particle, an electron has no real identity... but does that mean that your statement is inapplicable (trying to define something undefinable), or that you're explicitly wrong, or that you're still right but it just doesn't matter. \$\endgroup\$ Commented Jun 3, 2022 at 11:54
  • \$\begingroup\$ By the way (going on a tangent here, hardly related to the question any more), do you know whether electrons in a current exclusively move in one direction? Or could there be "turbulence" that causes some of them to actually go upstream, as long as the net displacement follows the current? If so, that poor electron might find its way home just yet. \$\endgroup\$ Commented Jun 3, 2022 at 11:59
6
This is a model, or ideal circuit, that is a useful approximation (in many cases) to a real world circuit.
If we wanted to use a circuit model to take account of the charges on the surfaces of the wires, and on the dangling connection to the top capacitor, then we would add extra capacitor components, and label them Cstray. For typical circuits they would be quite small, often just a few pF, to correctly account for the amount of charge that's there at battery voltages.
If the components shown in the circuit are in the nF or uF region, then you can see that the stray capacitance absorbs so little charge that we can safely ignore it, compared to the charge on the main components.
Not all teachers make this approximation aspect of circuit theory clear, it seems yours hasn't. It's always a problem when teaching a potentially very complicated topic. Do you make the approximation explicit and frighten the noobs, or just present the approximation and leave the deeper thinkers mistrusting what you've said?
Note that even when we have modeled the distributed charges with stray capacitors, we only have a better description of some real physical circuit, not a correct or ideal one. The actual circuit will have conductors that have some physical length to them, and so have inductance, or might even need to be treated as transmission lines or antennae. In the limit, we can always find some operating condition or accuracy level that defeats a circuit model.
Depending on the frequency we want to operate at, and the accuracy we want, the trick is to model the circuit in as few ideal components as possible, and still capture the behaviour that we are interested in. We often sum it up in the aphorism by George Box, All models are wrong, but some are useful.
The easiest way to handle surface charges is to use a fields and charges model, rather than a circuit model. This is ideal for capturing the electric fields as the result of some geometry of voltage sources and wires. While that model is very good for electrostatics, it's not the right tool to attempt to describe circuits with.
  • \$\begingroup\$ In EMC you usually consider the 'air capacitance to ground' stray as 4pF nominal. It's surprisingly good as a rule of thumb value. But in these case you also consider the capacitor lead inductances and wiring resistances… I guess the OP is at the 'pure electrostatic physics' level \$\endgroup\$ Commented May 24, 2022 at 8:10
  • \$\begingroup\$ @LorenzoMarcantonio yes I am seeing it from electrostatic point of view,,,also even if I assume for now that the carges on the open capacitor and wires is so small that we can ignore them,,,but even if its small its there right,,so does it mean that the incoming and outgoing current in the battery would not be equal here? so wouldn't it charge the potential difference of the battery? \$\endgroup\$ Commented May 24, 2022 at 8:18
    \$\begingroup\$ @ArunBhardwaj All of what you're saying is correct, at some level. If you want to illustrate it with a circuit model, then just sprinkle around the extra components that will absorb charge in the right places, and restore circuit theory's charge rules. You could even have a stray capacitor to the middle of the battery if you wanted. But we rarely do that because it's just too complicated. If we want to represent surface charges in a detailed way, then we use a fields and charges model, which can represent them much more easily, but then it's far too complicated to represent a 'circuit' easily \$\endgroup\$
    – Neil_UK
    Commented May 24, 2022 at 8:22
    \$\begingroup\$ @ArunBhardwaj Read the George Box article, this is one of his quotes ` 2.4 Worrying Selectively - Since all models are wrong the scientist must be alert to what is importantly wrong. It is inappropriate to be concerned about mice when there are tigers abroad.` Those stray Cs are mice. However, your teacher has not told you what sort of zoo he is showing you around. \$\endgroup\$
    – Neil_UK
    Commented May 24, 2022 at 8:47
    \$\begingroup\$ @ArunBhardwaj will I get to know more about "how electricity actually travels" when I'll study at higher level? Yes and no. Yes, you'll get to know more, transmission line theory for RF engineers for instance, and Fermi levels for hole and electron transport in semiconductors (did you know a hole is just as 'real' a particle as an electron?). Everything, no, because even those are approximations. It's all emergent from quantum theory. This is why teachers don't spell out their approximations, but present them as 'truth', as 'lies to children'. \$\endgroup\$
    – Neil_UK
    Commented May 24, 2022 at 8:53
