I need to plug a couple of sensor cables into these sockets but the plugs supplied on the cables don't match the sockets and I have not been able to identify anything that looks close so far. I am no electronics expert and am probably not being accurate enough with my terminology to help narrow the search online enough. So any help from this forum would be great.
The sockets are about 9mm x 3mm, and contain these four prongs that the plugs need to accept which are not small and square or round like most seem to be but wide and in a vertical orientation. The lower two corners of the sockets have triangular-ish fills and there are two holes in the top face of the socket to accept locking bumps on the top of the plug – if I don't get an exact match to the type I can trim the corners of a squared-off plug if needed.
