I'm sorting an old collection of electronic components, some of which I don't know what they are used for, like this one:
This component is about 7 mm wide. Does anyone recognize this? Thanks in advance!
EDIT: with scale
EDIT: with scale
It is most likely a type of 4-pin transistor mount. Similar results can be found by Googling "TO-5 transistor socket".
Looks like a 4 pin ZIF carrier.
The arms probably flip up, which allows a fragile or flimsy component lead to be inserted.
Then the arms would flip down and the assembly would plug into another connector.
It may be used for transistors, or possibly for sensor wires.
or
It could be the core from a connector.
It clips onto the end of a 4 wire cable, as described above, but the rest of the connector is missing.
