I'd like to use the PIC18F25K83-E/SS micro controller with the TCAN332 transceiver to implement a CAN node. In the PIC documentation it specifies the BOSCH CAN 2.0 standard while the TCAN322 specifies the ISO 11898 high speed physical layer. Are these two standards compatible? My understanding is that since one is specifying the physical layer and the other is specifying the transfer layer that they should be compatible (assuming all other nodes on the bus use the same setup of course). Is this assumption correct?
Thanks!
