This is related to my earlier question on driving dual coil latching relays from a single logic signal.
This question is on how whether the TI CD14538BM96 monostable multivibrator can be used to convert an input signal with very long pulse durations into edge-triggered output pulses of a shorter, well-defined duration:
In case it is relevant to the answer, let's assume that I use the leading- & trailing-edge re-triggerable configuration.
How will this device behave in response to input pulses that are longer than the configured output pulse duration?
- Will the output pulse length always be of the configured length beginning with time of the last matching edge?
- Or will the output pulse length be dependent on the much longer input pulse length?
Initially I thought 2 would apply, but after some reflection I more or less convinced that 1 applies. Can somebody confirm this either way?
