I have made a home made power supply using an LS-A7632-PT transformer I yanked from an old electronic. It takes 120v input and steps it down to somewhere around 6v and has two 6v legs. I then have a full bridge rectifier and a 6.3v 2200uF capacitor for leveling out the peaks. This goes to a smaller 354 ceramic capacitor then to the l7805CV 5v voltage regulator out to another 104 ceramic capacitor then to a connection terminal.
I read 4.98v and 4.97v on both of the terminals which is really good. I try to power my raspberry pi up with it, the light comes on as though it is working then it turns off then back on, then off repeatedly. I have read that the PI needs at least 2 amps for certain types of functionality and at a minimum 1 amp to work.
I have been unable to find the amp output of the LS-A7632-PT but I imagine it can probably put out plenty of amps as I measure the gauge of wire from the 6v output it has 22AWG copper from what I can tell.
I believe this is rated for max 7 amps. If this is the case, I would only be limited by the 1N4001 diodes and they are capable of carrying 1 amp from what I can tell. Am I doing something wrong for the needs of the power supply?
