It's impossible to increase the CCM duty cycle on a fixed load without the output voltage changing. Consider the DCM flyback case: -
The slopes of the rise and fall of transformer current are wholly dictated by \$V_{IN}\$ and \$V_{OUT}\$ for an inductor of a fixed value. And, because there is a period at the end of the transfer phase in DCM, duty cycle variations are permissible: -
But, CCM has nowhere to accommodate a change in duty cycle: -
The images above come from my basic website and are for a flyback converter with a 1:1 transformer. I also have a waveform generator that you can use for testing the change from DCM into CCM as the load current increases. This is an example for a 1:1 transformer where the output voltage equals the input voltage (125 volts). DCM Operation is at 100 kHz with a 1000 Ω load: -
If I decrease the load to 800 Ω, operation is on the boundary between DCM/CCM: -
If I lower the load to 600 Ω, operation is clearly in CCM: -
The duty cycle cannot change because there is nowhere to accommodate that change hence, the whole primary and secondary waveform rises.
How do flyback converters operating in CCM regulate their output?
It naturally regulates in CCM due to the way the slopes of primary and secondary currents link together.
What is the controller doing to maintain the output voltage if the
duty cycle is constant like that?
The controller doesn't need to do anything, it naturally happens once CCM is entered.
If the charging phase of the switching cycle begins when there is still magnetic energy in the transformer core (left over from the transfer phase) then, the charging current has to commence at a positive value and not a zero amp value (as in the case of DCM). That cannot be avoided in CCM.
Simple example of a flyback converter with fixed duty and switching frequency
The image shows a flyback converter's current waveforms from the instant power is applied. Although the duty cycle and switching frequency are fixed, CCM is naturally entered in the first few cycles but, after the output voltage rises towards a settled value, DCM takes over: -
- The red part of the waveform is charging current and,
- The green part of the waveform is the transfer current to the load
- Red remains fixed in duration and angle
- Green starts shallow and gradually becomes steeper
